  • Portal
  • Forum
  • Stats
  • Member List
  • Help
  • Calendar
  • Search
    • Advanced search
    • View New Posts
    • View Today's Posts
  • Account
    Username
    Password
    Lost Password?
    Register
sidebar change background page page_wide text color
The Human Bots › Gaming › General Discussion v
« Previous 1 2 3 4 5 ... 9 Next »
› Killing Floor 2 - ZED Time mechanics
Thread Rating:
  • 0 Votes - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Post Reply
Threaded Mode | Linear Mode
06-03-2015, 11:18 AMPost: #1
Dwel13R Offline
THB Member
Posts: 396 Joined: Feb 2005 Reputation: 3
submitted 1 month ago * by cat_is_fine_too(^._.^)?
Disclaimer: there might be errors here, don't consider all information as a fact.
ZED Time in Killing Floor 2 happen during killing ZED s or killing players. If ZED dies under other circumstances his death also may cause ZED Time .
ZED Time duration is 3 seconds.
ZED Time is a timer (float value 3.0000). It goes down from 3.0000 to 0 and resets back to 3.0000 as long as player's perk can do that.
Note 1: ZED Time cannot really be extended by certain amount of seconds. Instead it gets reset. Non-commando perk can reset ZED Time only once. Commando perk can reset it up to 6 times: levels 1-4 - 1 reset (just like every other perk), levels 5-9 - 2 resets, levels 9-14 - 3 resets, levels 15-19 - 4 resets, levels 20-24 - 5 resets, level 25 - 6 resets. ZED Time will be reset as soon as another ZED will be killed. For example Support can accidently reset ZED Time just because his shotgun has killed few ZED s by penetration.
ZED Time slows world to 20% of its normal speed (i.e. by 5 times).
Minimum interval between ZED Time s is 10 seconds.
Base chances to get ZED Time are:
Player kills ZED (within 300 units of range) = 2.5%.
Player kills ZED (range > 300 units) = 5%.
ZED kills player or another ZED = 3%.
Commando extension = 100%.
Boss dies = 100% (duration - 6 seconds).
In addition to base chances following events also has their chances to cause ZED Time :
Player kills 4 or more ZED s with an explosion = 5%.
Player kills 2-3 ZED s with an explosion = 3%.
Player kills ZED with a headshot (within 50 units) = 5%.
Player kills ZED with a headshot (range > 50 units) = 3%.
Note 2: These chances are separate. You have 5% chance to get ZED Time when killing a ZED and same time you have 5% chance to get ZED Time upon headshot.
Following chances increases in time if time passed since the last ZED Time is:
10 seconds - no ZED Time chance.
10-30 seconds - normal chance.
30-60 seconds - 2 times better chances (x2).
60+ seconds - 4 times better chances (x4).
How it works:
With each ZED / Player killed, game roll the dice (uses FRand() function that returns random float value between 0 and 1). Then checks if this value is greater or less than base chance (3% = 0.03, 5% = 0.05 etc.). If this value is less than base chance, ZED Time begins.
This post was last modified: 06-03-2015 11:20 AM by Dwel13R.
Search
Quote in reply
Post Reply
Search
  • View a Printable Version
  • Send this Thread to a Friend
  • Subscribe to this thread
Forum Jump:
User(s) browsing this thread:
1 Guest(s)
  • Contact Us
  • The Human Bots
  • Return to Content
  • Lite (Archive) Mode
  • RSS Syndication
  • Return to Top
  • Quick Language Select
Powered By MyBB, © 2002-2026 MyBB Group.
Theme Designed by Johnny S
